Stuffing box replacement
  • MikeC
    • Apr 2007
    • 535
    • Georgia
    • 1999 Ski Nautique (Python powered) 2017 GS22 (sold) 2005 SV211 (sold)
    I just picked up a '95 ski nautique and one of my winter projects is to replace the strut bearing, while I'm doing that I'm thinking about replacing the stuffing box with a dripless shaft seal. Has anyone here done this before? And, if so, where do you port the water from for the dripless seal?
    Thanks in advance.
  • 96SNEFI
    • Oct 2006
    • 36
    • BC, Canada
    • 1996 Ski Nautique with EFI
    I've been using a California Marine - Catalina Performance Parts shaft log for a number of years now. No water supply, no packing. No drips.
    • t.franscioni
      • Jun 2014
      • 715
      • United States
      • 2002 SANTE
      I'm going to install drip less packing also and plan on tapping into the pressure side of the raw water pump right after the Vdrive cooling section of the line.
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        So these dripless packings are neat and all, but I have to ask: What problem are you trying to solve?
        If your existing stuffing box is just dripping occasionally, leave it alone. It's fine. If it leaks a pint of water a day it's nothing to even bother with.
        -Charles
        • MikeC
          • Apr 2007
          • 535
          • Georgia
          I'm not trying to solve a problem - I'm just thinking about an upgrade. I'll have the prop shaft out to change the strut bearing so I was thinking about upgrading the stuffing box as well.
          • charlesml3
            • Jan 2008
            • 2454
            • Lake Gaston, NC
            • 2022 G23
            Ok, but it really isn't an upgrade. It won't perform any better than a traditional "drippy" stuffing box. If it bothers you that it drips, then by all means replace it. I just don't think this is something that needs to be changed unless it's really causing a problem.
            -Charles
            • MikeC
              • Apr 2007
              • 535
              • Georgia
              Thank you for your opinion, and I don't disagree with you. However, my original question wasn't should it be done, it was has it been done?
              • keithh2oskier
                • Jul 2015
                • 126
                • Sacramento
                • 02 Ski 196 SE
                Never done it myself but what are the risks if the dripless system itself fails? Can it? I have never used one before.
