Intermittent lack of power with diacom results 06 SAN TE ZR6
  • Ra140
    • Jul 2016
    • 8
    • Italy
    • 2006 SANTE 210
    Hi I am having a bit of trouble with an 06 SAN 210 TE I recently bought. It started with it being in limp mode with an error message Ignition fault see dealer. I replaced the throttle position sensor and sorted that problem. It has LPG and petrol and on LPG it runs perfectly but on petrol it doesn't give full power. Strangely for about 3 days it seemed to clear itself and ran well but now it is back to giving me reduced power. Initially it seemed to be in limp mode but it isn't anymore as the lack of power can happen at any rpm that it decides rather than the 2500 RPM that it did before. Again at the start when it was at idle it ran well but now it seems to want to cut out and then adds a little power to stop that and it never actually cuts out. I don't want to start replacing a lot of different parts (the TAC or ECM) to source the problem if I don't need to as there are no PCM dealers or really anyone with a similar boat nearby. I should add that the problem only happens under load, it will operate normally with the neutral lockout pressed at all RPMs and sometimes revving the boat in neutral can clear the problem but that could be a coincidence.
    Thanks for the help.
    PERFORMANCE DATA
    Parameter Description Value Unit
    Engine Speed.......................................... 0 RPM
    Calibration Checksum............................... 8B57 HEX
    Desired Idle Speed.................................. 744 RPM
    Engine Running Time................................ 0,00 Min
    Battery Voltage................................... 12,50 VDC
    Engine Hours...................................... 911,3 hrs
    ECT Temperature.................................... 20,8 °C
    Run Time 0-1000 RPM............................... 409,6 hrs
    Manifold Air Temperature.......................... -40,0 °C
    Run Time 1001-2000 RPM............................ 124,7 hrs
    Baro Derived From MAP............................. 100,4 kPa
    Run Time 2001-3000 RPM............................ 179,9 hrs
    Manifold Absolute Pressure........................ 100,0 kPa
    Run Time 3001-4000 RPM............................ 191,9 hrs
    MAP Sensor Voltage................................. 4,76 VDC
    Run Time 4001-5000 RPM.............................. 5,1 hrs
    Injector Bank A Pulse Width........................ 25,4 ms
    Run Time Over 5000 RPM.............................. 0,1 hrs
    Injector Bank B Pulse Width........................ 25,4 ms
    Max Engine RPM logged ......................... 5851 RPM
    IAC Position...................................... 254,0 #
    Knock Time.......................................... 0,2 hrs
    IAC Throttle Follower............................... 0,0 #
    ECM Hardware Version.................................. 4 #
    Throttle Position.................................. 14,8 %
    ECM Software Release................................. 18 #
    Throttle Sensor Voltage............................ 0,00 VDC
    ECM Software Revision............................... 161 #
    Closed Throttle...................................... ON
    Engine Displacement................................. 6,0 L
    Spark Advance....................................... 0,1 DEG
    Diagnostic Input.................................... OFF
    Engine Knock........................................ OFF
    Fuel Pump Output.................................... OFF
    Knock Retard....................................... 0,00 DEG
    Gen Warning 1 Input.................................. ON
    Octane Rating Adapt................................ 99,6 %
    Gen Warning 1 Lamp Output........................... OFF
    Cam Retard......................................... 0,00 DEG
    Check Gauges Lamp Output............................ OFF
    Fuel Flow Rate..................................... 0,00 LPH
    Low Oil Pressure Input.............................. OFF
    Engine Type........................................... 8 #
    Malfunction Indicator Lamp........................... ON
    Starts Without Malfunctions........................... 0 #
    Rev Limiter Status.................................. OFF
    Number of Cylinders................................... 8 #
    Shift Interrupt Input............................... OFF
    Starts Without Warning.............................. 255 #
    Warning Buzzer Output................................ ON
    Total Trouble Codes................................... 8
    RPM Reduction Control............................... OFF
    Disable Injector Bank............................... OFF
    Cam Sensor Present................................... ON
    58x Crank........................................... OFF
    7x Crank............................................ OFF
    24x Encoded Crank.................................... ON
    TAC Module Present................................... ON
    Emergency Stop Enable............................... OFF
    Speed Sensor Present................................. ON
    EGR Present......................................... OFF
    Two ATM MAP Present................................. OFF
    MAT Sensor Present.................................. OFF
    GPH Calculation Enable............................... ON
    Peak & Hold Injectors............................... OFF
    Skip Double Fire..................................... ON
    Relearn Closed TPS.................................. OFF
    Alternate Fuel Spark Curve.......................... OFF
    Allow Cyl Balance Test............................... ON
    Allow Paired Firing.................................. ON
    Bypass Spark System................................. OFF
    Multiple EST Outputs................................. ON
    Spark Current Clamped............................... OFF
    Load Anticipate 1 Enable............................ OFF
    Load Anticipate 2 Enable............................ OFF
    Adapter Load 1 Enable............................... OFF
    Adapter Load 2 Enable............................... OFF
    Knock Detection Enable............................... ON
    Governor Sync Enable................................. ON
    Governor Controls MPH............................... OFF
    Governor Present..................................... ON
    Twin Shift Sync Enable.............................. OFF
    Upshift Control Enable.............................. OFF
    CCP Enable.......................................... OFF
    Troll Mode Enable................................... OFF
    Shift Interrupt Enable.............................. OFF
    Shift Interrupt Kill Enable......................... OFF
    RPM Output Enable................................... OFF
    Fuel Temp Sensor Present............................ OFF
    Fuel Pres Sensor Present............................ OFF
    Wide Range O2 Sensors................................ ON
    Oxygen Sensor 1 Present.............................. ON
    Oxygen Sensor 2 Present............................. OFF
    Governor Speed Lamp Enable........................... ON
    Bosch MAT / MAP Sensor.............................. OFF
    Buss Master ECM...................................... ON
    Octane Adapt Enable................................. OFF
    Variable Speed Gov Enable............................ ON
    Emergency Stop Input................................ OFF
    Troll Mode Input.................................... OFF
    Low Oil Level Input................................. OFF
    Gen Warning 2 Input................................. OFF
    Low Oil Level Lamp Output........................... OFF
    Gen Warning 2 Lamp Output........................... OFF
    RPM Based Output.................................... OFF
    Monitoring For Knock................................ OFF
    Logged NV RAM Fault................................. OFF
    Stall or Reset...................................... OFF
    Logged RTI Overflow................................. OFF
    Troll Mode.......................................... OFF
    Low Oil On Last Check............................... OFF
    Oil Draining Back................................... OFF
    Upshift Conditions.................................. OFF
    Shift Interrupt Kill Mode........................... OFF
    Closed Loop......................................... OFF
    Oxygen Sensor 1 Rich................................. ON
    Oxygen Sensor 2 Rich................................ OFF
    Governor Over MPH................................... OFF
    Governor Over RPM................................... OFF
    Governed RPM Speed.................................. OFF
    Governor MPH Control................................ OFF
    Governor RPM Control................................ OFF
    Octane Adapt Active................................. OFF
    Oil Pressure Sensor Voltage........................ 5,00 VDC
    Vehicle Speed....................................... 0,0 KPH
    Gov Desired TPS.................................... 99,6 %
    Gov Motor Duty Cycle................................ 0,0 %
    Canister Purge Duty Cycle........................... 0,0 %
    ETC Pedal Position.................................. 0,0 %
    ETC Throttle Sensor Counts........................ 31981 #
    ETC Desired Pedal Position.......................... 0,0 %
    ETC Desired Throttle Counts....................... 32000 #
    ETC Pedal Sensor Counts............................ 2560 #
    Oxygen Sensor 1 Voltage............................ 1157 mV
    Oxygen Sensor 2 Voltage............................. 464 mV
    Oxygen Sensor 1 Transitions......................... 0,0 #
    Oxygen Sensor 2 Transitions......................... 0,0 #
    Block Learn Cell.................................... 0,0 #
    O2 Sensor 1 Block Learn........................... 128,0 #
    O2 Sensor 2 Block Learn............................. 0,0 #
    Desired EGR Position................................ 0,0 #
    Actual EGR Position................................. 0,0 #
    Absolute EGR Error.................................. 0,0 %
    EGR Duty Cycle...................................... 0,0 %
    Fuel Pressure Volts................................ 3,21 VDC
    Fuel Temp Sensor Volts............................. 0,00 VDC
    3. TROUBLE CODE STATUS
    Current ECM Codes
    (81) Throttle Actuator Control (TAC) Malfunction
    (81) Inj A High
    (81) Inj A Low/Open
    (81) Inj B High
    (81) Inj B Low/Open
    (81) 5 Volt Reference Malfunction
    (81) TAC Fault - Serial Communication Fault
    (81) TAC Fault - Lmtd Authority
  • Ra140
    • Jul 2016
    • 8
    • Italy
    • 2006 SANTE 210
    Not much help on this problem but in case someone has something similar in the future I thought I would update the thread. A lot of troubleshooting found me at the ECM and more specifically a faulty injector driver. Send it to PCM who agreed and plugged a new on in today and all is well again. If anyone comes across a similar problem in the future feel free to message and Ill give more details as swapping out an ECM is expensive if you are not sure its the right part!
