2014+ fuel filter change
  • UofM21
    • Oct 2013
    • 88
    • op[][
    Is there a write up on this? I believe there are two filters, but are there any special instructions to replace them? Thanks in advance.
  • xrichard
    • Aug 2008
    • 671
    • El Dorado Hills
    • 2023 G23
    There are instructions in the PCM owner's manual. On my 2015, the primary fuel filter is a spin on canister located in the rear starboard side engine compartment--it looks a bit like a large oil filter and spins on/off in the same fashion. The secondary filter is the fuel control cell and it uses a cartridge filter. The manual details the procedure, but basically you drain the fuel from the metal cell/canister then unclamp the FCC metal canister, drop it down, r&r the cartridge and reinstall. It has two o rings that need to be lubricated.
    The only difference between my 2015 and my previous boat, a 2008, is that the primary filter used to be an in-line filter under the cockpit that used hose clamps instead of the current spin on canister. I'm not sure in which year this changed.
    Previous boats:
    2015 G23
    2008 SAN 210
    2002 XStar
    1995 Sport Nautique
