Bilge Pump Relocation 2006 211
  • Ross-SV211
    • Jul 2015
    • 42
    • Lake Milton, OH
    • Then: 1998 Ski Nautique Now: 2006 SV211
    Hey all,
    Looking to see if anyone has relocated the factory bilge pump for a 06 211. The factory pump is located up near the ski locker by the driver seat. When there is a little water in the back of the boat near the engine, the forward position of the pump does not really do much since the water mostly sits near the back of the boat.
    I was thinking of relocating it where the V-drive/drain plug access hatch is located. Looking inside that small access door by the drain plug, I can see what looks like part of the "belly" tank. Is that going to prevent me for moving things around easily?
    *I have a port ballast tank leak which is why I'm getting a little water in the boat. Something I'm going to correct this winter. However, I still think having the pump that far up is kind of silly.*
    I appreciate the feedback!
    -Ross
  • jbach
    • Aug 2012
    • 187
    • the state, not the jelly
    • 1999 SAN
    i own a 210, not a 211, but i almost guarantee you have two pumps in that boat. if not, there should be. should be on the same circuit. do some serious looking around in front of the rudder port.
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      Yep, there are two pumps. one near the rudder and one in the ski locker behind access hole.
      2005 SV-211
      • xlair
        • 694
        • Wisconsin
        Your rear pump may be clogged.
        2001 Pro Air Nautique
        • nukemustang
          • Sep 2014
          • 410
          • Summerville, SC
          • Current Boat: 2018 GS20
          "I was thinking of relocating it where the V-drive/drain plug access hatch is located. Looking inside that small access door by the drain plug, I can see what looks like part of the "belly" tank. Is that going to prevent me for moving things around easily?"
          This tank you speak of.... when you look into the little access to pull the plug, are you looking forward? if so that is the gas tank. When I fill the boat up, I usually hop up in, flip the lid and watch the boat fill up, I am able to prevent it backing up and splashing all over the side of the boat that way.
          Tim
          • Ross-SV211
            • Jul 2015
            • 42
            • Lake Milton, OH
            Hey All,
            thanks for the feedback so far. I'm going to check the rear pump to see if it's clogged.
            • Ross-SV211
              • Jul 2015
              • 42
              • Lake Milton, OH
              What's the best way to access the rear pump? I'm having a hard time even getting a look at it. Thanks!
              • Paxdad
                • Mar 2013
                • 775
                • Cumming, GA
                • 2008 210 SANTE
                Remove the muffler??
                2008 210 SANTE
                • Ross-SV211
                  • Jul 2015
                  • 42
                  • Lake Milton, OH
                  Hi Paxdax,
                  It looks like the sides of the engine bay are removable and might give some more access to those areas. I was really hoping to avoid doing any major work. I have no idea what I'm getting into by removing the muffler. lol Thanks for the reply!
                  • rossrips7
                    • Feb 2010
                    • 233
                    • Unknown
                    You can just remove the dividers and hard tank if you have them
                    • homer12
                      • Feb 2016
                      • 584
                      • Indianapolis, IN
                      • 2004 SV211 TE
                      Definitely remove the dividers and like Rossrips7 said, if you have the hard ballast tanks you can remove those for more access.
                      • Ross-SV211
                        • Jul 2015
                        • 42
                        • Lake Milton, OH
                        Sounds good! Thanks for the feedback!
