2007 SANTE blower bilge and ballast switches stopped working
  • Gwojcik7
    • May 2016
    • 25
    • Finger Lakes, NY
    • 2007 Super Air Nautique 220 Team Edition
    Hi all, I have an 07 SANTE. the bilge switch on my dashboard stopped working about a month ago. Recently the blower also stopped working. Last trip out I couldn't get the ballast pumps to work. When I click the button the light turns on and I hear a small click at the controls but nothing turns on. Any ideas what could cause this?
    thanks!
  • Gwojcik7
    • May 2016
    • 25
    • Finger Lakes, NY
    Any ideas?
    • nukemustang
      • Sep 2014
      • 410
      • Summerville, SC
      • Current Boat: 2018 GS20
      so the light comes on the keypad, but the item does not start? Where exactly is the click? the PME box (mine is under the dash, by the drivers feet) or the keypad? I know several people here have had to replace the key pad.
      I doubt that 5-6 separate items have failed in the last month (3 ballast, blower and bilge pump(s)) so you have to start looking at what is common. At the top of this page, there are wiring diagrams, you can use those to see if you are getting +12V at the item when you push the key pad (choose the most convenient place) if you aren't getting it, the PME box, or the key pad is probably failing.
      Tim
      • Gwojcik7
        • May 2016
        • 25
        • Finger Lakes, NY
        Is there any chance it could just be a bad fuse?
        • Gwojcik7
          • May 2016
          • 25
          • Finger Lakes, NY
          The light at the keypad will turn on and off and you hear something click at the keypad but nothing kicks on.
