Someone told me that the water pump is supposed to drip a little. I've never heard this. Is it that it's supposed to, it's OK if it does, or neither? Thanks.
Tags: None
No, it should not leak.
No, should not leak. I had mentioned in other posts that the original rear cover had a paper style gasket. There were a batch of early pumps that had cover issues. Years ago PCM sent me a replacement pump and the new one uses an o-ring for the seal. Actually, when you order the PCM replacement impeller, you get both an o-ring and paper gasket. I curse that paper gasket every time I see it. I spent too many hours trying to stop the original pump from leaking.
