'04 SANTE strainer location
  • Bad Cad
    • Mar 2016
    • 19
    • Stone Bank, Wisconsin
    • 2004 SANTE 210
    The strainer in our boat isn't bolted down, although it does have a bracket. Someone must have moved it from the factory position. It's just being held up behind the ski pylon frame by the two hoses, and I can't see any open holes where it used to be mounted. Can someone with a '04 SANTE or similar vintage please take a picture of how the strainer was mounted at the factory? Thanks.
  • Quinner
    • 2246
    • Correct Crafts
    Not VDrives, but none of my CC's has had the strainer attached to anything except the two hoses.
    • rossrips7
      • Feb 2010
      • 233
      On my 02 sante it's mounted the the ski pylon frame
      • Kmayotte
        • Apr 2010
        • 819
        • Lake Winnipesaukee, NH
        No picture for you but I used to own the same boat. There was a mount made of sheet metal that held it from the left side (looking rearward) by the area where one hose connected to the strainer. The hose passed through a hole in the sheet metal.
        • tachudda
          • Jul 2015
          • 54
          • Orlando, FL
          • 2004 SANTE 210
          Got an 04 SANTE, ours dangles
          • XBIGPUN66
            • Oct 2012
            • 456
            • WI
            Ours was mounted to a bracket on the wall by the pylon
            Sent from my SAMSUNG-SM-G930A using Tapatalk
            Ian S
