The strainer in our boat isn't bolted down, although it does have a bracket. Someone must have moved it from the factory position. It's just being held up behind the ski pylon frame by the two hoses, and I can't see any open holes where it used to be mounted. Can someone with a '04 SANTE or similar vintage please take a picture of how the strainer was mounted at the factory? Thanks.
- Apr 2010
- 817
- Lake Winnipesaukee, NH
- 2016 G23, 1999 SN Python Past: 2004 SANTE, 1993 SN
No picture for you but I used to own the same boat. There was a mount made of sheet metal that held it from the left side (looking rearward) by the area where one hose connected to the strainer. The hose passed through a hole in the sheet metal.
