went to local auto shop to buy oil since its time to winterize. Pcm manual calls for 15w40 gf-4 sm. The problem is that all of the 15w40's are diesel. I don't recall having this problem over the last 3 years but I'm sure I could be wrong. Local marina recommended 25w40. I would prefer to stick with what the manual says. Any recommendations out there?
Proper oil for 2012 210
'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'12 SAN 210 TE Black/Masters Blue
'09 SAN 210 TE Black/Fury Red
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190Tags: None
- Mar 2002
- 16453
- Lake Norman
- Mooresville, NC
You're running into the same problem discussed here. The manual is wrong. That weight and rating do not exist.
https://www.planetnautique.com/vb5/f...-specificationI own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by scottb7 View PostLike the oil, if you plan to change the filter every 50 hours the brand does not matter, in my opinion. No one will ever own a boat long enough or be able to tell one way or another if it mattered what oil type or filter brand was used.
- Jun 2008
- 2080
- Flowery Branch GA Lake Lanier
- 2008 210 SANTE 67 Correct Craft Mustang
I use Mobil 1 15W50 in all my boats its the only weight recommended for both roller and flat lifter engines. Remember using synthetic oil doesn't mean you can go over on change intervals. I change every 50 hours and suck out the trans oil as well. As for filters Purolator gold ,Mobil 1 and K&M are some good ones
- Aug 2016
- 481
- Austin, TX
- current: 2006 Cobalt 343 with twin 525hp Mercs former boats:'99 Air, '12 210, '10 230, '07 236, '06 211, '05 220, '06 220, '06 210
+1 to Delo 15w-40, this what i ran in my most recent change. oil pressure dropped about 3 psi from old oil at idle and OT. after this change (rest of the season and drop it before winter storage) i plan on trying amsoil brand new semi-syntethic blend in 15-40. it offers crazy water protection supposedly. still lubricates with 10% water dilution.
