I'm in the process of winterizing my sv211 for the first time and while running antifreeze via the fake-a-lake, it eventually starting to come out of the shaft seal. I can see the antifreeze in the water filter, but it's yet to come out of the rear exhaust port? I got nervous when I saw it coming of the shaft so I aborted. Anyone experienced this before and/or know why?
Shaft seal will have a cooling tube going to it from your cooling system so if you are injecting antifreeze into the cooling system it will come out down the shaft because that also happens with water when you run it up on the trailer and you may have not noticed
Sent from my SM-G900I using Tapatalk
IMScarlet, thanks for the reply. If it's running out of the shaft seal, does that mean it's cycled completely through the block? I pulled a couple of plugs afterwards and antifreeze came out. Just being extra cautious since this is the first time wtih this boat.
A d m i n i s t r a t o r
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
How much antifreeze have you used? It should come out of the exhaust once it is all the way through the system. It can take five gallons or more before that happens.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
