1999 Air - refurbish windsheild weather stripping?
If you're talking about the weather striping that rest under the frame, then yes, buy new it's cheap enough but, if you're referring to the gasket that the glass fits into the frame then you would have find a source for it but, again it shouldn't be too expensive.
This is the weather stripping that I wanted to clean up some. I did not see it on the website linked above. Any ideas? If I do need to replace, have ya'll done this before?
I was doing some digging and it looks like in the late 90 they used a rubber piece as the screw cover, this is what I think you have. The replacement is plastic but does fit. You will see if you remove it, it covers the screws, hence the name. Use the code PND and you'll get 10% off at Nautique Parts.
Not sure where you can find a rubber screw cover but the plastic on looks better.
