Well today was the day that the mechanic was supposed to go take a look at the boat that I am looking at purchasing. However before he went to look at it we spoke on the phone and (without having even seen a picture of it) He tells me that "that vintage of Nautique are full of problems stay away" He wouldn't even go look at the boat, and didn't even ask any questions about it.
Issues he noted:
Computers are prone to fail, and no longer available
Wire harness is prone to fail, and no longer available
Rudder shaft is weak and will "break off hitting a fish too hard"
Prop shaft is 1" which is weak and is easily bent/unbalanced (on this note, the boat does have a vibration that comes in around 2,000rpm, but quickly goes away.) Prop shaft? Or could it be the broken tracking fin?
He also said "surfing isn't going to happen with that boat" Which I have seen photographic evidence to the contrary on this site.
He then suggested I look only at Malibu because they are the "best boat made hands down"
I think the guy just didn't want to make the 1 hour drive to look at the boat.
I have done a lot of research on these particular boats and I have not found any of these issues reported. In fact they seem to be held in fairly high regard for reliability and build quality. Being that the mechanic backed out I am just planning on inspecting it myself in person when I get home in a week. (pictures are from girlfriend looking at it.)
After my research thus far, and Noel looking at the boat in person, we were kind of set on a SAN for our first boat.
If anyone has any input, or feedback we would really appreciate it.
Has anyone experienced any of the above mentioned issues?
Are the points valid in anyway, or is this dude crazy?
Some pictures below.
-Needs upholstery sooner rather than later
-Slight vibration around 2k RPM that quickly dissipates
-Teleflex gauges have been replaced with Faria already
-Has tower speakers amp and newish JVC BT head unit
-Comes with 2 ea. 550 sacs and a wakeboard
-no perfect pass
-broken tracking fin ($100on Nautique Parts)
-370 hrs
Should I bring anything to an on water inspection other than a compression tester?
Anything else to look out for?
Thanks again!
Issues he noted:
-no perfect pass
-370 hrs
Thanks again!
