Harmonic Balancer tourq spec GT-40
  • Grant_West
    • 758
    • Redwoodcity Ca
    I was wondering if anyone knew what the tourqe spec for the harmonic balancer was on my GT-40 is
    Im looking for the spec of the Large nut in the cent as well as the 4 smaller ones surrounding the pully
    Thanks G
  • gotpwr
    • Aug 2004
    • 244
    • Louisville, KY
    • None
    RE: Harmonic Balancer tourq spec GT-40
    The center crank damper bolt torque spec is 90 ft-lbs. I couldn't find the torque spec for the pulley bolts, but they're not as critical, so just make sure they're "tight".
    2000 Air Nautique Powered by FORD <-- Former Boat
    • Grant_West
      • 758
      • Redwoodcity Ca
      Thank You :grin:
      • clayk
        • Jul 2004
        • 72
        • mont.,al
        you can just look for torque specs on 3/8" bolts , or just make them about as tight as as your alt. bolts
        • farmerandy
          • May 2006
          • 13
          • Boyd Texas
          PCM service manual says 35-50 ft-lbs.
