I went to replace my 7 year old optima battery with a new one...but my battery cable just pulled off due to a broken terminal. ( I guess this could be the source of my low voltage readings?)
Anyway, I need to replace this terminal...
1.) Is there a way to replace this like the factory without soldering, running a new cable or having an industrial strength cable crimper?
2.) If not, should I use just use the cheapo replacement shown below? If so, ..do I need to take a hacksaw to the cable?
