2016 G23 w/ XR7 engine: requires 93 octane, but only 92 oct. widely available locally
  • sarasetp
    • Oct 2016
    • 112
    • Bellevue
    • 2016 G23
    Pretty much every gas station around here only carries 92 octane as the highest grade gas I can get. Would it cause issues in my XR7 engine (long or short term) if I went with 92 Octane?
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Call PCM customer service and talk to a tech service rep.
    you'll be fine.
    PCM probrably has the best customer service of any company under correct craft.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • DW SD
      • Mar 2015
      • 416
      • San Diego county
      • 2001 SAN 210
      All new engines have knock sensors (I assume XR7 is new-ish?). If the fuel grade is too poor, the knock sensor will report detonations (pre-ignition / knocking) to the computer, which will retard the timing. This will de-power, likely not noticeably, but will avoid damage. I'm confident you'll (well your engine to be more accurate will) be fine.
      The dealer could likely poll the computer's diagnostic data to find knock events (usually they are recorded) if you were wanting to be extra cautious.
      I wouldn't steer you this way. The onboard fault protections make for very safe engine operations even on lesser fuel grades.
      Doug
      • ironj32
        • May 2011
        • 600
        • 2018 SAN G23 XR550
        Everything will be fine with 92 octane. I've never had an issue.
        2018 SAN G23 XR550
        2015 SAN G23 XR550
        2014 SAN G23 XR550
        2013 SAN G23 XS550
        2013 SAN G23 ZR450
        2011 SAN 230
        2010 SAN 230
        2000 XStar
        www.mnspringride.com
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Agreed. One point of octane difference isn't going to matter.
          -Charles
          • chief351
            • Aug 2007
            • 107
            • Ontario
            • 2015 SN200 ZR409
            If the computer pulls timing (1-2 degrees) and spark for one point of octane you'll lose 5-10 horsepower, you won't notice enjoy!
            New ride 2005 SN 196
            Sold 2010-09-05 - 1990 SN - 610 hrs
