I have been scouring my V Drive and engine compartment for the hex nut that drains the water from the transmission cooler. It is labeled the raw water drain plug on p.29 in the manual Can anyone help me understand where this is located? I have found the Raw water circulation Pipe, Know Sensor, Port side Manifold, Starbord Drain plug, Starbord Manifold drain, the V Drive Drain, but I can not for the life of me find the transmission cooler drain plug.
Tags: None
There is a little metal cylinder in the cooling lines that is about 3" in diameter and about 8" long. Look under the starboard side of the engine laying in the hull. I think a 3/4" heater hose runs through it. there is a small 1/4" square plug in it. The transmission cooler is the cylinder I described.2005 SV-211
Originally posted by homer12 View PostI've always thought you could pull the raw water cooling hose connected to that metal cylinder to drain also. Can someone confirm that?
