I'm looking for con rods, need two or a set. Skidim want 170 USD each for PCM con rods. Does anyone know if I can use an alternative. I have seen sets at Summit for around 200 USD upwards, any recommendations on a good set or alternative that will do the job.
RE: GT40 connecting rods
I don't know this for sure but I believe the PCM rods are just standard Ford Truck rods. You can get a nice set of Eagle I-beam rods at Summit for about $275 and they are good for 6500RPM and 500HP which should be more than adequate.2000 Air Nautique Powered by FORD <-- Former Boat
