Hey fellas,
I recently bought a 99 air nautique DD and am in the process of cleaning her up and improving the ballast. I've got a few questions.
1). The stock pumps for the ballast do not work, and have not worked for some time. That being said, I can only find one of the stock pumps...next to the engine. Can someone point me in the right direction to find the second pump?
2). I think the second pump is under the floor between the engine and rear seat. This panel, that has the access hatch to the prop shaft, was broken before I bought the boat and needs to be repaired anyway so I need to remove it to repair and access the second stock pump...I think. Any thoughts on how to remove/repair that section of floor?
3). Finally, I picked up a used Jabsco puppy that I would like to use but not sure where to mount it. I've read some of the great threads about upgrades but still looking for more ideas. Any thoughts are appreciated.
Thanks guys.
Thanks guys.
