Clean up engine bay / corrosion from salt water?
  • prorider17
    • Jun 2016
    • 14
    • Ormond Beach, FL
    • In-between boats at the moment
    Hi all. I've been looking for a used SAN210, and came across a coastal edition. It appears to be in fair shape, but the engine pulleys, alternator and riser gasket has a little bit of corrosion / rust. What else should I be concerned about in terms of wear/tear on this boat. It's closed cooled. I would like find replacement pulleys and swap out the gasket/alternator.
  • Outdoorjp
    • Jul 2016
    • 178
    • Carlsbad
    • 2011 SAN team 210
    Risers need to be checked for rust since salt sits in them.
    trailer galvanized?
    Spray everything with corrosion X. motor mounts also.
    if it's just surface rust scotch Brite pad. and wipe respray.
    I spray everything metal down every other trip and extra good for winter in engine bay.
    • azeus17
      • Feb 2008
      • 387
      • Grand Rapids, MI
      • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
      What year is it? When I lived in a saltwater environment, the electrical and wiring were my biggest issues. If you are able to, pull a few wires to see how they look.
      • DW SD
        • Mar 2015
        • 416
        • San Diego county
        • 2001 SAN 210
        I'd probably remove the pulleys and have them powder coated.
        I use my boat in a salt water lagoon and spray all the fasteners and any exposed metal in the engine bay with CRC heavy duty corrosion inhibitor. It is like an aerosol version of cosmoline (yellow wax which drys over exposed metal hardware). I apply it to the trailer chains, fasteners, etc. It works great. Buy it at Amazon.
