Same thing here w my 17G23. Starboard says 100% full, I empty, go to the music screen, the tank status screen, and the ballast says 100% again. How many hours are those pump impellers rated.for ?
- Oct 2014
- 1026
- St. George, Utah
- Red Metal Flake 2016 G23! Malibu 25 LSV 2019 2021 Centurion Ri237
I have 300 hours on my 2016 impellers and they still seem to be working fine. I will be replacing them right away, just because I am a fan of keeping things in top shape and not replacing them once they break. Then I will have 3 spares when the new ones fail after 30 hours
UPDATE : We have had Link/ Ballast problem 99% resolved Dealer replaced flow sensors & updated the link, 1% problem we can work with meaning after pulling boat out at ramp car park was not level showed incorrect ballast but corrected its self after travelling home & stored in level garage
We found best way to check if ballast impellers are worn is set link to pro rider fill ballast after pumps have stopped manually over fill each one if water not coming out overflows within 30 seconds we know its time to replace impeller normally get around 200 hours or 2 seasons before need replacing which do all 3 at once
We have a 2017 GS20, no problems first year. This year port ballast showed 63% full when boat went into water. ballast was actually empty. Can drain until indicator shows 0%. When we go to fill the level goes immediately to 100% and stops, ballast is still empty. Now also does same on belly ballast. Currently can't use any ballast as only the starboard will fill/drain. No faults shown. Any way to override the auto shutoff when level shows 100%? Dealer wants back to look at but we are 3 hours away.
Originally posted by mattst View PostWe have a 2017 GS20, no problems first year. This year port ballast showed 63% full when boat went into water. ballast was actually empty. Can drain until indicator shows 0%. When we go to fill the level goes immediately to 100% and stops, ballast is still empty. Now also does same on belly ballast. Currently can't use any ballast as only the starboard will fill/drain. No faults shown. Any way to override the auto shutoff when level shows 100%? Dealer wants back to look at but we are 3 hours away.2012 SANTE 230
Originally posted by mattst View PostThanks Wakerider107! We will give that a try. We will try at 15-20 mph also just in case pumps are not primed.
my screen hasnt shown accurate levels since i got the boat. they say 100%, but if i cycle the pumps again they will run for a couple more minutes before spitting out the side of the boat.2012 SANTE 230
Just took delivery of ‘18 G21 with 30hrs. My first Nautique. First ride port ballast won’t discharge - dealer replaced pump and all good. Back on water next weekend and now having issues as noted above with stbd ballast display showing 100pct when clearly empty. No matter how much attempt to drain, snaps back to 100pct immediately upon trying to fill. Short-term going to try and disconnect sensor located at very back stbd side engine compartment and see if it fills. Real fix is new sensor it seems. Ugh!
- May 2013
- 2795
- Smith Mountain Lake, VA (Craddock Creek area)
- 2017 G23 Coastal Edition H6 | 2001 Sport Nautique | 1981 Ski Nautique
Originally posted by Ianmic View PostJust took delivery of ‘18 G21 with 30hrs. My first Nautique. First ride port ballast won’t discharge - dealer replaced pump and all good. Back on water next weekend and now having issues as noted above with stbd ballast display showing 100pct when clearly empty. No matter how much attempt to drain, snaps back to 100pct immediately upon trying to fill. Short-term going to try and disconnect sensor located at very back stbd side engine compartment and see if it fills. Real fix is new sensor it seems. Ugh!
- Sep 2016
- 447
- New York
- 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
