Originally posted by Ianmic
View Post
- Oct 2014
- 1026
- St. George, Utah
- Red Metal Flake 2016 G23! Malibu 25 LSV 2019 2021 Centurion Ri237
Originally posted by Ianmic View PostI dont see how I can override from the cockpit on either the ballast screen or the surf screen with user settings. It's show 100% and so pump runs for 10s and then trips off either way. Is there another software angle to override?
I also never got this problem resolved. My local dealer has been no help - maybe because I didn't buy from them (I moved), or maybe they just don't have a resolution. Regardless, this is a pain because it renders rider profiles mostly useless.2012 SANTE 230
Originally posted by mikenbike211 View Post
It needs a new sensor. They get water inside the connectors and Corrode internally. Nautique still doesn’t have a real “fix” and will continue to pay for replacements until a better sensor is obtained. When the ballast reads 100% and you know it’s actually empty, scroll down to the settings screen and then choose a screen that I believe says “power diagnostics” tell me what the suspect sensor voltage reading voltage is in the lower rh corner of the screen.
What's this say to you mike? None of pumps running when took the pic.
- Sep 2016
- 447
- New York
- 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
- May 2013
- 2795
- Smith Mountain Lake, VA (Craddock Creek area)
- 2017 G23 Coastal Edition H6 | 2001 Sport Nautique | 1981 Ski Nautique
Ok. As long as you’re POSITIVE (put boat on trailer or up on hoist and press empty) that the ballast is physically empty. You have a sensor issue. It needs to be replaced. For now, unplug that sensor and the system will use the timer half of the system, then cycle your battery switch off. Then, You will need to fill (let fill until it stops itself), and then drain (again until it stops). Should be calibrated now for the timer.
- Oct 2014
- 1026
- St. George, Utah
Don't use the rider presets. If you just turn on the pumps in the main menu, they will run until you shut them off or they overheat.
