196 with no throttle
  • JohnW
    • Dec 2016
    • 1
    • New Zealand
    • 2006 Ski Nautiques 196
    My 2006 196 ZR6 starts and runs but has no throttle control ie won't rev up, also noticed Rev counter doesn't work although this may be unrelated. Any ideas as to why I can't rev engine ?
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    I think 06 was when drive by wire was introduced, I'd pull the engine cover off and make sure the throttle cable is working correctly and moving the electronic throttle control. Could be something with the throttle position sensor maybe?
    1989 Sport Nautique
    • Laptom
      • Oct 2003
      • 876
      • Eindhoven, Netherlands
      Tps broken. I also had this with our 2007 zr6. Quick fix.
      Verstuurd vanaf mijn SM-G901F met Tapatalk
      • 911
        • Dec 2016
        • 2
        • Lebanon
        • ccr ski nautique 2004
        The rpm gauge has nothing to do with the no throttle problem , i would advice to replace the Throttle position sensor if the cable is working properly
