2008 SAN 230 / 343 Excalibur alternator upgrade
  • shag
    • 2217
    Has anyone changed their 70 amp alternator for the 100 amp, in a 2008 era SAN with the 343? They are about the same price, but Nautiques parts shows a retrofit kit that you need for $300 http://www.nautiqueparts.com/alterna...00aalt60l.aspx
    Does this kit simply plug into the existing harness?
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    Whats in the "kit"? Sounds like these are entirely different alternator series. Different electrically, size and mounting points.
    • shag
      • 2217
      Not sure what is in the kit. If i look up part numbers there is also a 'jumper' for either a 70 amp or 100 amp that may or may not be needed. I asked my dealer about this a few weeks ago and they weren't sure about changing to a 100amp, in fact I think they said you can't do it. NP is closed for the holiday.. Maybe Skidim would know.
      • scottb7
        • Aug 2011
        • 2198
        • Carson City, Nevada
        I think the kit includes the alternator and the harness. See other one labeled kit shows alternator.
        http://www.nautiqueparts.com/alternators.aspx
        • shag
          • 2217
          I sure hope that is the case... I was looking aftermarket for the alternator.. Looks like they can found around $150.... Then you'd have to buy the harness... Think it's all plug and play with the new harness?
          • scottb7
            • Aug 2011
            • 2198
            Probably...
            • Quinner
              • 2246
              • Correct Crafts
              The stock alternator on that motor should be 100amp not 70amp??? PCM went 100amp on all their motors back in the early 2000's IIRC
              • aaronmt
                • Jan 2016
                • 53
                • Washington
                • 2006 SAN 220 TEAM
                I'm under the impression it should be a 100amp as well.Our 06 Zr-6 is 100amp and I've been looking to upgrade that as well.
                Sent from my XT1254 using PLT Nautique mobile app
                • ski4evr
                  • May 2010
                  • 613
                  • Bowling Green, KY
                  • 2005 SV 211
                  If you click the more info button, you will see all pcm since 2005 have the 100 amp. only the 2004 serpentine had the 70.
                  2005 SV-211
                  • shag
                    • 2217
                    Interesting, my dealer told me after looking that it was the 70 amp... I'll try to see if I can find a part number on it. Thanks for the replies.
                    • MLA
                      • Dec 2009
                      • 1312
                      In most cases, the amp rating is stamped into the house, usually on one of the mounting bosses.
                      • ski4evr
                        • May 2010
                        • 613
                        • Bowling Green, KY
                        • 2005 SV 211
                        Your owners part manual found on this site does list both sizes and the retrofit kit also.
                        http://www.planetnautique.com/Correc...08PCMparts.pdf
                        Maybe it depended on accessories ordered with boat.
                        2005 SV-211
