Could FCC Filter Cause a Sudden Death?
  • rechevarria
    • 10
    Please forgive me for what is probably a dumb question, but I am mechanically clueless.
    Could a FCC filter problem cause an engine to die quickly?
    Here is the scenario: Was pulling a beginning skier with my 2004 SANTE. As soon as I gunned the engine, the boat hesitated, then died. It has not started since.
    Now it will turn over, but not start.
    Does this sound like a FCC filter issue?
    Thanks for any insight or information.
  • Onthewater
    • 695
    • Near the cheddar curtain
    RE: Could FCC Filter Cause a Sudden Death?
    are you getting spark?
    are you getting fuel?
    many things can cause a no start, does it ever act like it wants to start?
    I don\'t care.
    • Hollywood
      • Sep 2003
      • 1930
      • WIIL
      Yes, the FCC could cause this, especially the filter.
      • rechevarria
        • 10
        Not sure about getting spark and fuel. I assume it is getting spark, as it does try to start. After a couple short trys on the starter, it will turn for about 2 seconds, so it does sound like it wants to start.
        I can hear what sounds like the fuel pump coming on.
        I also made sure the kill switch was on good.
        Other than doing very, very basic stuff, I am clueless about doing too much troubleshooting.
        Thanks for everyones' info!
        • wakejunky
          • 679
          • Ca
          • 2003 SAN
          It sounds more like your kill switch, check the wires on the back side of the panel. One could have fallen off. Next would be the relays on the motor.
          Chris
          • M3Fan
            • 1034
            Next after that would be low volume fuel pump.
            2000 Ski Nautique GT-40
            2016 SN 200 H5
            www.Fifteenoff.com
            • krs0394
              • Jan 2006
              • 170
              • Sturgis, MI
              I had to replace the low volume pump on my 02. Did the same thing your are talking about. You are probably hearing the high volume pump. Loosen the bowl on the FCC and see if there is fuel in there.
              1973 CC Skier
              1989 SN 2001
              2002 SN 196
              2005 216 Limited
              • rechevarria
                • 10
                Thanks a million all for the information. I will do some more troubleshooting this weekend.
                • surroundsound64
                  • Jul 2005
                  • 2147
                  • Longview, TX
                  • 2018 230 1981 Ski Nautique
                  Sounds fuel related to me.
                  2018 SAN 230
                  1981 Ski Nautique
                  Sold - 2011 Sport 200V
                  Sold - 2000 SAN
