2003 gateway
  • dollar
    • Oct 2015
    • 2
    • winter haven fl
    • 1992 close bow
    2003 gateway
    I am having issues with my 2003 196 volt meter. My dealer says it's an gateway issue, I am looking for help on trying to fix this so my volt meter will work again. All help will be greatly appreciated.
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    Are you saying that your volt meter is not working at all or that it's low? If low, there was a known problem back then that the battery lead to the gateway box wasn't big enough and there was a voltage drop between the batter and the dash, causing PP to complain about voltage. So, a second battery lead wire had to be run from the battery to the gw box.
    • ffmedic74
      • 835
      • Lexington, KY
      Send me a pm if you need a new gateway and send a pic of your current one.
      Sent from my SM-G900V using Tapatalk
      • Quinner
        • 2246
        • Correct Crafts
        FFMedic,
        Betting his will have the pitot tubes
