I was going to wait till spring to announce this, but I have some possible good news for those of you worried about lack of replacement ECUs. I was working with some guys on another forum and was able to read the "tune" off the PCM marine ECU using Moates hardware. We found a couple vehicles that used the same hardware as the marine ECU and I was able to write the "tune" to an add-on chip that mounts to a port on these ECUs. It is winter in WI and I haven't been able to test it yet, but if it works everyone should be able to replace their broken ECU with another fairly common ECU and an aftermarket chip. The one issue is that the chip sticks out a little and the black ECU cover would have to be trimmed to get the ECU back in place. Again, this has not been tested yet...
OP might be the same user I pm'ed on the eectuning site...whatever came of this effort? did it work?
The boat I'm getting in a couple weeks has the GT-40, I'm a complete newbie so apologies in advance but, what exactly does this do?
Originally posted by gobluemike2142 View PostThe boat I'm getting in a couple weeks has the GT-40, I'm a complete newbie so apologies in advance but, what exactly does this do?2009 Super Air Nautique 210 TE
1989 Sport Nautique
Originally posted by ScooterMcgavin View Post
Mike this is info for you GT-40 owners that have an BAD ECU. Because they aren't able to be purchased anymore. This would be a fix to get the boat running again. Not a modification or anything, but great info for sure.
Wow. Ok good to know. I'll keep an eye here for more info as it comes in. Thanks.
I wasn't planning on it, but I just sold my boat and didn't get a chance to do any testing this spring. I do have the "image" file saved if anyone wants to test it out on their own, I can explain how to do it. I also have a ecm and a "burnt" F3 chip if someone wants to test it (we can work something out.) The C1A1 ecm out of the 2.3 liter Ford Mustangs use the same hardware as the marine ecms. I read the "image" file off my old boat and burnt it onto a F3 chip from Moates. That F3 chip when plugged into an ecm with the same hardware should work. The big question is whether or not I got a good "read" off my marine ecm, although I'm pretty sure I did. All anyone has to do is buy a C1A1 off ebay for $25-50 and buy a F3 chip programmed with the marine code. If we can confirm that this setup works, I would be happy to burn the chips for people in the future.
2008 SAN 210
1997 Sport Nautique
I would like to. Not that I need it mine works fine but just to have a back up. The image file is the PCM GT40 tune for the ecm? I recall with PCM that there was several versions of the GT40 tune, kept fine "tuning" it over the years. I imagine my GT40 being the last year of production has the most recent tune. What year was your GT40 that you copied from? Can the image file you have be emailed? Are you looking for any compensation for the image file?
^^^ that's what I was thinking. Thanks to all you guys who are on this. I copied the file from vanhanbr "just in case". Now, that being said, I have absolutely NO CLUE what to do with it but I'm guessing if the poop hits the fan some day I have at least this part covered. Fingers crossed that I never have to use it.
Odds are definitely in your favor Mike that you will never need it but it sure is great to have guys like Vanhanbr out there figuring fixes for difficult issues!!
Van you should post your findings on CCFan also, some GT40 guys over there who have been trying to crack those codes, Lewy in Australia being one of them.
