Decal removing/ Ordering Registration Decals
  • jondavis08
    • May 2016
    • 369
    • Battle Creek, MI
    • 2014 SANTE 210 2003 SANTE 210-Sold
    I know a lot of you are obsessed with removing all the warning decals on your boat. I like the cleaner look as well. With that being said what is the best way to safely remove decals? I also need to to add my new registration numbers, is there a good site to order some good color combos? I really like what the previous owner had on the boat(pic below), even though my state technically doesn't also the numbers to be the same color as the hull... Any suggestions what would look good against the red?
  • markj
    • 1194
    • NorCal
    For me it was finger nails, Goo Gone, occasionally some heat from a hair dryer and a ton of patience. I did a carbon fiber wrap over the capacity labels near the throttle. I'm pretty sure I don't have a single sticker left on the boat or tower except for the black chromax on the sides and transom. I've gotten away with no reg numbers for the last 6+ years, but I keep them in the glove box for when my number comes up with the popo. I bought my boat from the same place you did. I like how they order their boats.
    • swatguy
      • 1630
      • Midwest/ Northern IL
      • 2008 SANTE 210
      Use a heat gun to warm up the decals you want to remove. Use some goo gone and acetone to clean up the leftover glue.
      There is no better site than Domednumbers.com
      • Evening Shade
        • Apr 2015
        • 1295
        I second Domednumbers.com.
        • bandit628
          • Sep 2016
          • 318
          • Southern Illinois
          • Current-2012 SANTE 210 Past Boats 2000 Mastercraft
          Plastic razorblades work great for scraping. Buy a bunch they dull quickly, but do not scratch gelcoat.
          Also use heat as said before.
          Sent from my SAMSUNG-SGH-I337 using Tapatalk
          • Schwiiing
            • Mar 2008
            • 129
            • Norris Lake, Tn.
            • 2017 SAN G23 H6
            You can pick up a decal removal wheel that will fit on any cordless drill at most automotive stores. It basically a large gum eraser in the shape of a grinding wheel. I have used this on cars, trucks, and boats to remove small stickers to full boat graphics and it has always worked well. Just need to keep it moving and dont allow it to heat up.
            • peteSki
              • Mar 2005
              • 230
              • Ottawa, On, Canada
              • 2005 Sport Nautique 216 Previous: 1997 Ski Nautique
              I just removed the 10 year old registration numbers from the hull on my boat, a hairdryer to heat 'em up and then peel them off with fingers. Used a plastic scraper/spreader to scrape off most of the residual adhesive, then wiped with mineral spirits to get remaining adhesive off, then wash the area with soap and water suitable for fiberglass. Wiped dry and applied the new vinyl. Works great and there was no residual trace of the old numbers. Full removal process probably took my 20 minutes for each side.
              • swc5150
                • 2240
                • Eau Claire, WI
                • MasterCraft Prostar
                Hair dryer and 3M adhesive remover is what I use. Be very cautious with a heat gun, as you can easily melt through your gelcoat. I'll be removing all those ugly stickers off my new boat shortly as well.
                '08 196LE (previous)
                '07 196LE (previous)
                2 - '06 196SE's (previous)
                • Fgroce
                  • Dec 2016
                  • 179
                  • Middle Georgia
                  • 2002 Ski Nautique
                  I second the 3M decal eraser wheel. I used one wheel to take off all the decals on a 2002 Ski Nautique and it worked like a champ. I spent the 25 dollars to get a 3M instead of a knock off. I did not want it to come apart in my face while I was running it. I worked great no damage to the gel coat and it was quick.
                  • ScooterMcgavin
                    • 1478
                    • 2014 SAN 210 TE
                    +3 for the 3M decal remover wheel.
                    1989 Sport Nautique
