What does 2:1 Transmission mean and why is it significant?
  • sarasetp
    • Oct 2016
    • 112
    • Bellevue
    • 2016 G23
    Stupid question...What does 2:1 Transmission mean and why is it significant? I have the xr7 550 engine.
  • t.franscioni
    • Jun 2014
    • 715
    • United States
    • 2002 SANTE
    Two revolutions of the engine for every one revolution of the transmission/your prop. The significance has everything to do with boat size/weight, available engine power, prop size and pitch.
    • t.franscioni
      • Jun 2014
      • 715
      • United States
      • 2002 SANTE
      The significance is greater with the smaller engines because they need the lower gear ratio to push those big boats. In your case the significance could mean that you can weight your boat down even more than if you had the smaller engine with 2:1 and still have no problem pushing all the weight, or it could mean you can run a higher pitched prop and get more top end speed out of your G than one without the 550. It could mean a few different things depending on what you were wanting to do but in short you theoretically have more options than those without your setup. Does your 2:1 with 550 come with the same prop that the smaller engine boats come with?
      • Sailfun
        • Dec 2016
        • 131
        • Lake Norman NC
        • 2018 Nautique G23 2022 Robalo 226
        It really means nothing as far as torque multiplication or RPM. All that can be adjusted with prop pitch changes. What it does allow is using a larger diameter prop within the pitch ranges that produce the best performance by a prop. The old rule of thumb was you wanted to keep pitch and diameter roughly the same. Most direct drive boats ran 13x13 props. When V drives became popular and inboards doubled and tripled in weight you needed a lot more power. A13x13 can't move enough water. Vdrives went to 1.5 to 1 gear sets and 14x18 props but the pitch was getting up there and not as efficient as you want. Now you have 2 to 1 drives using 17x17 props which is a efficient combination.
        • t.franscioni
          • Jun 2014
          • 715
          • United States
          • 2002 SANTE
          Oh ya, I forgot about the V drive factor....So the 2:1 means 2 revolutions of the tranny input shaft for every revolution of the transmission output shaft. Not engine to prop....
          • nyryan2001
            • Mar 2013
            • 1993
            • Lake Anna
            Sara step, I'd be intersted to know your 0-23mph speed with full 2850lbs ballast.
            the 0-23mph for a 450 1.48:1 on a 2315 prop was ~13 seconds
            450hp on a 2:1 17" prop was 9-10seconds
            550hp on a 1.48:1 15x14.75 prop was ~8seconds
            550hp on a 2:1 17" prop????
            2019 G23 450
            2014 G23 550
            2013 G23 450
            2011 Malibu Wakesetter 247
            2007 Yamaha AR210
            • ScrewPusher
              • Feb 2006
              • 77
              • Isle of Wight County, Va
              I remember a good rule of thumb is a larger diameter propeller turns slower, and is more efficient (up to some point). This was very clear when I had SN with the power plus 1.23:1 trans versus someone w/o and 13X13 prop. Dang that was a fun boat!!!!
              • beaster
                • Jan 2017
                • 26
                • Austin TX
                • 1995 Malibu Response 2004 Nautique SV211 2014 Nautique G21
                I have a 2014 G21.
                I had to have my VDrive replaced over winter. My previous Vdrive was 2.0. The new Vdrive is a 1.48, dealer sourced and installed. That's roughly a 25% difference in ratio.
                Since the replacement I have a heck of a time getting on plane with 3 crew and a few hundred pounds of ballast, it literally takes me minutes, not seconds. Its a 17" prop (2561) pushing a lot of weight. The 1.48 gives me less revolutions of the prop per revolutions of the engine (I think).
                Is this what's causing me to have a hard time getting on plane?
                • t.franscioni
                  • Jun 2014
                  • 715
                  • United States
                  • 2002 SANTE
                  If the dealer didn’t install the same ratio that was in it before and didn’t warn you there will be some noticeable differences then that’s not a dealership I would trust. I’d think changing the ratio that much would certainly cause you issues getting onto plane. To run a higher ratio gear box you’ll now need to try and compensate for that with a lower pitched propellor. Id contact your prop manufacturer and have them work the math on what pitch is needed to compensate for the higher geared box you have now.
                  • functionoverfashion
                    • Jun 2017
                    • 509
                    • New Hampshire
                    • 2003 SANTE
                    Seriously, we replaced an old 1.23 with a 1.46 (can't remember why) and had to change props to get the same performance, I can't imagine your boat would be happy with a 2:1 to 1.48:1 change, if the prop stayed the same.
                    • JRW160
                      • Jun 2011
                      • 42
                      • Huntsville, AL
                      • 2016 G23
                      Originally posted by beaster View Post
                      I have a 2014 G21.
                      I think the 2013 G23s had the old 1.5:1. They switched to 2:1 in 2014 for all of the engines except the 550. You may be able to mitigate it by changing props, but I'd go back and get the 2:1 installed.
                      • Jonny Quest
                        • Aug 2014
                        • 384
                        If you keep the new V-drive gear ratio, you will definitely need a new prop…smaller pitch for sure and maybe even smaller diameter. I can’t understand why the dealer didn’t discuss this with you prior to installation. To go from 2:1 to 1.48:1 is a big jump. No way would the boat perform the same with the prop sized for the 2:1 and now running 1.48:1. It would be like riding your 10-speed bicycle uphill in high gear from a standing start.
                        JQ
