Engine idling high?
  • lakejoe
    • Feb 2005
    • 28
    • Lake Norman NC
    Engine idling high?
    I Have the excalibur 330 in the boat. Engine idles high(1700-1900 rpms) randomly when pulled back into neutral. Not everytime but occasionaly. Anyone have an idea what the issue could be?
  • ryanandrews
    • 233
    • chippewa lake ohio
    RE: Engine idling high?
    got the same problem on my 1994, its the 5.8 pro boss carbed.... i put some marvel mystery oil in the gas tank and hasn't did it again...yet?..............bad gas?
    • Quinner
      • Apr 2004
      • 2246
      • Unknown
      • Correct Crafts
      I have had a similar problem with an 05 w/Excal, dealer said it could be the perfect pass/throttle cable hitting the shroud or whatever you call the cover on top of the spark arrester, I removed shroud and problem was less frequent. My boat is at the dealer right now for that and a couple other problems.
      • CTRider
        • Jul 2005
        • 31
        • Sandy Hook, CT
        I just had the same thing happen to me. Do you have perfect pass? If so look at the attached picture. And you will see the L adapter and the allen bolt. My L adapter an allen bolt started to corrode together causing the L adapter to stop spinning freely this was causing the cable to stop while the throttle was still open a little bit causing the high RPMs. I took it all apart and got it to move freely again and the problem is now gone.
        • lakejoe
          • Feb 2005
          • 28
          • Lake Norman NC
          CTRider,
          Nice diagram! I will check that on mine. Thanks!
          • winebrad
            • Apr 2005
            • 90
            • Napa, CA
            • 2002 Air Nautique 216 Excaliber 330
            Just had my 2002 Air with the 330 Excaliber and PP in with the same problem and the dealer adjusted the shroud. Great diagram! I have not had my boat out yet but I will definately reference to you diagram.
            Brad
            02 Air
            • ag4ever
              • Feb 2004
              • 1180
              I had the problem with the shroud hitting the perfect pass cable. After the dealer trimmed the shroud, it has been fine.
              • nms1991
                • Apr 2004
                • 477
                • Unknown
                RYANANDREWS your problem sounds like the secondaries are hanging up when you return to idle way to find this out is to run the boat and when the high idle problem occurs go to the carb and look and see if the linkage on the carb can be moved and the idle will drop down to normal. If it does then you must look at the cab because the throttle plates are hanging due to corrosion or wear to the throttle shaft.
                • CTRider
                  • Jul 2005
                  • 31
                  • Sandy Hook, CT
                  Thanks but the Diagram came from the perfect pass website which I did not find until after I resolved my problem.
                  • ag4ever
                    • Feb 2004
                    • 1180
                    nms1991,
                    The excalebur 330 is efi, not carb, so there are no secondaries.
                    • gdhall
                      • May 2011
                      • 122
                      • Bainbridge, Ga
                      • 2003 SANTE 210
                      Where is this diagram you are speaking of? My 03 SAN with 330 did this today at first but stopped after the first run. We have to idle a nowake zone for a while after putting in and it's super annoying going in and out of drive to stay at no wake speed
