2007 sante gauge issues
  • Jtb1
    • Feb 2017
    • 2
    • Alabama
    • 2007 super air nautique TE
    Has anyone had the same issues I am having? I have a 2007 sante with perfect pass. My analog oil pressure and temperature gauges aren't working. The digital read out screen in the tachometer is reading zero oil pressure, zero hours , but reads voltage correctly. I replaced the oil sending unit, with no change. I trouble shot oil pressure by pulling sending unit and testing oil pressure with a Matco test gauge. Good strong oil pressure on test gauge. Has anyone had an issue like this before?
  • Quinner
    • 2246
    • Correct Crafts
    Sounds like a Gateway box issue, check all your connections are firmly in place, also check your breaker panel, had a similar issue and it was one of the breakers, don't recall which one but the tag was not clear it was gauge related. If neither works you may want to remove the gateway and open it up and check for moisture issues. Good Luck!
    • Jtb1
      • Feb 2017
      • 2
      • Alabama
      I will go ahead and check all connections and breaker panel. Is it ok to use CRC electronic cleaner on connections and gateway box?
      thank you.
