My 03' Flight Clip spacer
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    I had the same problem as everyone else with boards hitting the front tower leg. I decided to do something about it by putting a 1/2 spacer between the bar and the flight clips.
    Took 1/2 stock, cut it to size, drilled holes, powder coated, used longer bolts and walla.
    Should take care of the problem
    See below
  • actiondcpd
    • Jan 2004
    • 147
    • Cardiff, CA
    RE: My 03
    You make that from stock alunimum?
    • wakejunky
      • 679
      • Ca
      • 2003 SAN
      RE: My 03
      Yep. Went to my local scrape metal shop and bought 1/2" by 2" Al. and then cut them to size.
      Chris
        • 2908
        RE: My 03
        Nice job Chris!
        Did you consider using ABS or Black plex? Might be a little easier to do, you could even have Tap cut and polish it for you. Since the load is in compression plex probably has adequate mechanical properties to handle the load.
        Mike
