2005 211 speed issues
  • Diana Fechner
    • Mar 2017
    • 2
    • Phoenix, Arizon
    • 05 211
    Alright guys! I have a 2005 211, I have recently replaced the throttle cable and throttle sensor. My problem increased! Now, when I drive at random times, the boat will either randomly speed up or slow down by itself? I dont know when it is going to happen. I have to pull the throttle back and shut it down. then start it back up again. Any suggestions?
  • homer12
    • Feb 2016
    • 584
    • Indianapolis, IN
    • 2004 SV211 TE
    Maybe obvious but are doing anything with PerfectPass? Assuming that's the speed control you have
    • Quinner
      • 2246
      • Correct Crafts
      For sure sounds like a perfect pass issue, in 2005 the throttle is mechanical so not likely the cause of your issue.
      Turn perfect pass off and I am betting that will solve your issue.
