Why is my strainer cup so hard to get on and off?
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    My strainer cup on my 2014 210 is very hard to get on and off compared to my old boat 2005 sante. It almost seems as if I would need a wrench.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Ian S
  • Dandy21
    • Jun 2014
    • 159
    • Minnesota
    I am pretty sure these have a square shouldered gasket (think oil filter gasket) instead of an o-ring. If so, they bind more and do not release as easy. If you can pick up some silicone (not petroleum based) gasket lubricant and lube the gasket, it will still seal will but will remove much easier next time. If the gasket is not lubbed, the dry rubber binds against the dry plastic. We use the following around our shop on filter gaskets and orings.
    https://www.grainger.com/product/JET...rchQuery=2ykJ9
    You can most likely find a smaller container much cheaper than this.
    • XBIGPUN66
      • Oct 2012
      • 456
      • WI
      I used grease and it is still very difficult. The one in my old boat was very much easier.
      Ian S
      • XBIGPUN66
        • Oct 2012
        • 456
        • WI
        It is hard to turn for the entire threading.
        Ian S
        • scottb7
          • Aug 2011
          • 2198
          • Carson City, Nevada
          i agree...always hated that thing....
