Cylinder 1 missing
  • bandit628
    • Sep 2016
    • 318
    • Southern Illinois
    • Current-2012 SANTE 210 Past Boats 2000 Mastercraft
    Cylinder 1 missing
    1st day on the lake. Nautique 210 with 343. Cylinder 1 missing error, vibrated pretty bad at idle. Much less at higher rpms.
    Going to replace spark plug. The old one looked ok. Last season I just had full engine tune up done with all new plugs and wires. Was done at nautique dealer.
    Any place I should start?
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    Did they change the rotor and cap too?
    1989 Sport Nautique
    • bandit628
      • Sep 2016
      • 318
      • Southern Illinois
      Yes.
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        So start with the easy things and work your way through. It sounds like this engine has a cap & rotor style ignition. Check to make SURE the plug wire for cylinder 1 is pushed down tight on the spark plug and the distributor cap. If that doesn't resolve it, replace the spark plug. If that doesn't fix it, replace the plug wire. If that doesn't fix it then it's probably a crack in the distributor cap.
        -Charles
        • Quinner
          • 2246
          • Correct Crafts
          That particular GM cap is known to fail prematurely, if the plug looks good and wire was secure try a new cap. If still an issue try swapping plug wires, if issue moves to the swapped cylinder replace all the plug wires.
          • bandit628
            • Sep 2016
            • 318
            • Southern Illinois
            Thanks guys.
            I was wrong in saying the plug wires are new. But the spark plugs, rotor, and cap are all new.
            The problem is much worse once the engine warms up. In just see searching this problem in general, could it be an O2 sensor?
            • charlesml3
              • Jan 2008
              • 2454
              • Lake Gaston, NC
              • 2022 G23
              An O2 sensor would not deactivate one cylinder. In fact, the part about it getting worse after it warms up tends to make me think distributor cap.
              -Charles
              • Fgroce
                • Dec 2016
                • 179
                • Middle Georgia
                • 2002 Ski Nautique
                I agree start with the cheap stuff first. Go plug, wire, cap and rotor button. If you still have a issue check compression, or you could have a bad fuel injector. Hope this helps.
                • homer12
                  • Feb 2016
                  • 584
                  • Indianapolis, IN
                  • 2004 SV211 TE
                  I'm not an expert here but I'd look to change the plug wires. If they heat up that could mean more resistance which would mean lack of voltage through wire to give you spark. Check obvious for tight connection first though as was already stated
                  • bandit628
                    • Sep 2016
                    • 318
                    • Southern Illinois
                    It wasn't the cap and rotor. Tried a new one with no change. Used a plug wire tester and it had good spark.
                    Didn't think about the heat causing resistance change. Might try new plug wires.
                    At this point probably going to take it to the dealer.
                    • DW SD
                      • Mar 2015
                      • 416
                      • San Diego county
                      • 2001 SAN 210
                      It could be a fuel injector. Injector wiring. Or a vacuum leak affecting that single cylinder too.
                      A NOID light will tell you if the injector is getting pulses. That would confirm the injector wiring.
                      If you have a compression tester you might also check for compression.
                      In the end you need air / fuel, spark and compression to run.
                      • rolleronariver
                        • Feb 2017
                        • 21
                        • Rogers, AR
                        • 92 Sport Nautique
                        I had a truck do this exact thing once. It ended up being the wire that was getting more resistance the warmer the truck got. $5 and it ran like new again.
                        • bandit628
                          • Sep 2016
                          • 318
                          • Southern Illinois
                          I hope it is something simple or at least fixable. At this point I'm in bit of freak out mode.
                          • vanhanbr
                            • Mar 2014
                            • 223
                            • Wisconsin
                            • 2008 SAN 210
                            I would start by bringing it back to the dealer that did the tune-up. No use guessing at stuff.
                            2008 SAN 210
                            1997 Sport Nautique
                            • DW SD
                              • Mar 2015
                              • 416
                              • San Diego county
                              • 2001 SAN 210
                              You can also isolate a cylinder which isn't firing as it won't be hot at the exhaust port. Do you have a $30 infrared temp gun (harbor freight or amazon is a good source)? They are quite a cool little tool. Pointing at the exhaust outlet before the riser should identify which one isn't firing. From there, you can make other tests.
                              Doug
