2008 PCM engine won't start
  • H2livin
    • Feb 2017
    • 12
    • Michigan / Ohio
    • 2008 Nautique 196 Limited
    I purchased my boat a couple months ago from a dealer used. We ran it on the lake and it ran no issues. I've not started it since then. Today I washed the engine compartment installed the battery and it won't start. It does turn over with no issue, I installed a new battery. I can't find any videos online showing what the 330 engine sounds like at start up but I don't hear the fuel pump kick on after entering my code. I'm not sure if it's suppused to start up and shut off like most fuel injections but I don't hear it doing anything. I've been turning it over and over and I don't smell any fuel being spent it just won't kick or do anything at this but mist turn over. The only thing to come on is the bilge pump and then shuts off I don't hear anything else. The dealer winterized the boat after we tested it I'm not sure if it's the fuel pump or is there something wet I'm missing. I checked the fuse for the pump as well and it appears to be ok.
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    Double check the lanyard, sounds like a kill switch issue.
    1989 Sport Nautique
    • jshack01
      • May 2012
      • 139
      • Louisville, Ky
      • 2020 Super Air Nautique G23 (Gold/Onyx Black) 2017 Super Air Nautique G23 (Indigo Blue/Onyx Black) 2012 230 SANTE (Red/White)
      I'll second ScooterMcgavin's comment.
      • H2livin
        • Feb 2017
        • 12
        • Michigan / Ohio
        Ok checked that and still nothing. I removed it while the "all on" switch is in the on postition and put it back in place and the dash all came on like normal tried to start it and it just turns over and nothing more. Should the fuel pump make any noise at all, I guess that's my main question as to how it's getting primed before actual turning over?
        • shag
          • 2217
          You should hear the fuel pump prime the fuel cell (FCC).
          • H2livin
            • Feb 2017
            • 12
            • Michigan / Ohio
            Fuel cell as in the fuel tank? Because I'm hearing nothing.
            • Quinner
              • 2246
              • Correct Crafts
              Put your hand on the low pressure fuel pump and cycle the ignition on, it is externally mounted pump near the FCC. If no noise or vibration probably your issue. Try a new relay or swap with the other one for testing, if not the relay the pump is probably bad.
              • azeus17
                • Feb 2008
                • 387
                • Grand Rapids, MI
                • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
                No, the fuel cell, or FCC, is a black cylinder that hold the fuel filters. It should be mounted near the front of the engine. Right next to it is the low pressure pump.
                • Quinner
                  • 2246
                  • Correct Crafts
                  The High Pressure Fuel Pump is in the FCC.
                  • wakejunky
                    • 679
                    • Ca
                    • 2003 SAN
                    I had a similar issue....Took the boat out, ran fine for more than 20 minutes and then sputtered and quit. Tried to restart and it just would't start. The fuel pump is turning on, I can hear it.
                    Where do I start my troubleshooting? Pull fuel canister? pull spark plugs? How do I check fuel pressure?. I'm terrible at troubleshooting so any help would be appreciated.
                    • shag
                      • 2217
                      Sounds simple but could be the Distributor cap..... I had one only last about 6 months.... Same issues - no start... Replaced the cap and bingo.... Started right up
                      • wakejunky
                        • 679
                        • Ca
                        • 2003 SAN
                        Does anybody have direct replacement automotive parts for the Cap/Rotor and spark plug wires for the Ex330? There isn't anything special about these items but, I think the spark plug wires are longer since they have to go down and around the exhaust manifold. I don't want to order online and would rather just visit my local auto parts store.
                        • xrichard
                          • Aug 2008
                          • 669
                          • El Dorado Hills
                          • 2023 G23
                          Caps historically are different because they're ignition protected. Could be that's old school (e.g. screen over vent hole) from back in the days of points and perhaps there is no difference today. In any event, I wouldn't use one not designed for an enclosed space. I don't know about the rotor, but they're cheap and if you're getting the PCM cap, you might as well get the PCM rotor.
                          Previous boats:
                          2015 G23
                          2008 SAN 210
                          2002 XStar
                          1995 Sport Nautique
                          • Quinner
                            • 2246
                            • Correct Crafts
                            I could find no difference between the GM cap and the PCM cap used on the Excalibur, my mechanic who is a GM expert could not either.
                            • wakejunky
                              • 679
                              • Ca
                              • 2003 SAN
                              Did a little bit of troubleshooting yesterday. Replaced cap and rotor and pulled a spark plug. the plug looked good. The fuel pump cycles when the boat is turned on and I can hear is cycle when I pull the lanyard kill. It'll turn over but, not catch.
