2008 PCM engine won't start
  • ski4evr
    • May 2010
    • 613
    • Bowling Green, KY
    • 2005 SV 211
    you can check that you are getting fire to the plug with a simple timing light. as the current flows to the plug, the light will flash. simple check to make sure it is actually firing.
    2005 SV-211
    • Quinner
      • Apr 2004
      • 2246
      • Unknown
      • Correct Crafts
      When you say the fuel pump is cycling, do you mean both the LP & HP pumps? You could dump a little fuel in the intake and see if it fires, if it does open the FCC, if it is not full of fuel it is likely the LPP. You will also want to check the relays as well.
      • erikj
        • Mar 2017
        • 50
        • Park City, UT
        I had a very similar problem and it turned out to be the the fuel pump relay, $11 part from napa
        Sent from my SM-G950U using PLT Nautique mobile app
        • Tryathlete
          • Feb 2015
          • 217
          • Lake Villa, IL
          • 1996 Nautique Super Sport
          GT40 starting and immediate stall is typical when the Low Pressure Pump is dying. One way to trick it is to keep the ignition switch in the full forward position after it initially starts and keep it there past the point where you hear it start for about two to three more seconds.
          • wakejunky
            • 679
            • Ca
            • 2003 SAN
            How much fuel pressure should there be on the Low Pressure pump? and High pressure pump? when in the On position, since it won't start.
            • wakejunky
              • 679
              • Ca
              • 2003 SAN
              #21
              I figured out my problem. I had disassembled the boat to do my floor and when I put the tank back, I crossed the return and feed lines to the pumps. So, I was pulling from the return line long enough until the tank ran low and the line could no longer pull fuel from the return line. Once I swapped the lines, it started up after two tries. I'm just thankful that it wasn't something serious and/or I couldn't figure out.
