I added two Rev 10's with RGB light rings and routed the RGB wire to the passenger side front of tower following the existing speaker wire. I'm unable to complete the run because the factory speaker wires are to tight running thru the tower into the boat.
Has anyone pulled the factory wire and added wire as thick as RGB to the harness back thru the tower bolt.
Any help would be great, I don't want to add unneeded hole to the boat.
Sent from my SM-G900V using PLT Nautique mobile app
