303 Fabric Guard to waterproof boat cover, how to best apply
  • sarasetp
    • Oct 2016
    • 112
    • Bellevue
    • 2016 G23
    I have used this and works really well. Would you all agree?
    I have not figured out a good way to spray this on. I am reluctant to spray it on the boat cover when the cover is on the boat. I am afraid of overspray hitting the gel coat of the boat or other parts of the boat and possibly ruining these items. I usually take it off and spread it on the ground, which I hate because I do not want dirt to get on the bottom side of the boat cover. The boat cover is so awkward to handle for spraying it.
    Do any of you have a great system for spraying on the 303 Fabric Guard on the boat cover?
  • rossrips7
    • Feb 2010
    • 233
    I've always heard of people using the pump sprayers you would spray bugs with. It helps giving you a nice even coat.
    • Neverenough
      • Sep 2012
      • 907
      • Ft. Worth Texas
      • G
      I did ours on boat with a bug sprayer. Worked fine except it doesn't seem last long. Someone posted after I asked that you should do light coats and not put on very heavy.
      • Paxdad
        • Mar 2013
        • 775
        • Cumming, GA
        • 2008 210 SANTE
        I have either draped it over my Yukon Xl and applied it or hung it from the rafters where I store my boat. I just used the hand sprayer it comes with as not to waste it. Tired hands in the end.
        2008 210 SANTE
        • Woody_tobius_jr
          • Dec 2012
          • 248
          • Alberta, Canada
          • 2004 SV211 Air Nautique TE
          I use a pressure pump as well, I pressure wash the drive pad down and keep the kids off of it until it dries and then I spread my cover on the pad and spray a couple of coats of 303 on it, letting each coat dry in between, been pretty happy with the results
          • MLA
            • Dec 2009
            • 1312
            • Lake Wylie NC Area
            with the cover cleaned and dry, lay it out upside down and use a clean pump up garden sprayer to coat the cover. Wet to just about pooling and let dry. Any pooling, spread with a clean brush.
            • Wake.BC
              • Jan 2016
              • 423
              • BC, Canada
              Just spread it out on some chairs on grass, so then it's off the ground and if it were to touch it's clean. I would not recommend spraying it on the boat, the 303 is very harsh
