2013 SN200 OB Rear Bilge Pump Removal
  • Big Air Dado
    • Apr 2017
    • 2
    • Oconomowoc, WI
    • 2013 SN200 OB
    The rear bilge pump in my 2013 SN200 OB runs continuously so I'd like to try to clean it and replace it if required. Does anyone have a recommendation on how best to remove the pump? I can reach under the gas tank and get my hand on the pump, but between the wiring hardness and the bilge hose, I can't pull it out enough to do any work on it. Any suggestions would be greatly appreciated. Thanks.
  • Big Air Dado
    • Apr 2017
    • 2
    • Oconomowoc, WI
    • 2013 SN200 OB
    I found the zip tie holding the harness. Good to go.
