2006 210 fuel in oil
  • prowakeskater
    • Aug 2016
    • 58
    • florida
    • 03 SANTE
    #31
    drain the fuel
    put 5 gallons of good shell or chevron gas in and run it
    • 93Euro
      • Feb 2006
      • 94
      • California
      • 2006 air nautique 210 SE
      #32
      Originally posted by DW SD View Post
      Are those platinum plugs? I had thought those were a no no for old-school distributor type ignitions.
      They are iridium. I did a search and got the info here. What do you suggest?
      • DW SD
        • Mar 2015
        • 416
        • San Diego county
        • 2001 SAN 210
        #33
        With old school, single coil systems, I use just the basic plug. I had thought sometimes the fancy platinum ones don't burn properly.
        From the pictures, it seems like something might still be off with the mixture or plugs (carbon fouled).
        • 93Euro
          • Feb 2006
          • 94
          • California
          #34
          Yeah still not running right. check out this video. If I ease into the throttle it runs ok. At the :48 mark, i gas it a little harder and it starts shaking and popping. I let off a bit and it starts running normal again. I decided i'll take it in to a local guy who can hook up to the computer and hopefully be able to figure it out. https://www.youtube.com/watch?v=4IrCjuapiiQ
          • prowakeskater
            • Aug 2016
            • 58
            • florida
            • 03 SANTE
            #35
            have you drained your fuel yet or are you just gonna continue running that **** fuel and expect different results
            • 93Euro
              • Feb 2006
              • 94
              • California
              #36
              I have not done that yet. It's one of the things that I need to do at least to eliminate that possibility. I just don't see it fitting my symptoms. But i will do it
              • prowakeskater
                • Aug 2016
                • 58
                • florida
                • 03 SANTE
                #37
                You needed to do that first
                • 93Euro
                  • Feb 2006
                  • 94
                  • California
                  #38
                  Not sure if it could have been my entire problem? But I changed my thermostat(that was stuck open) and I think my problem is gone. Could it have been that simple? I thought my temp gauge wasn't working but it was just never getting up to temp
                  • prowakeskater
                    • Aug 2016
                    • 58
                    • florida
                    • 03 SANTE
                    #39
                    thermostat has nothing to do with detonation
                    glad the new fuel fixed the problem
                    • 93Euro
                      • Feb 2006
                      • 94
                      • California
                      #40
                      My problem has been a rich condition from the beginning...never did get around to draining the fuel
