I was wondering if anyone has had experience with changing out an NSS Plate and actuator on a 2015 G23. I hit a submerged log in the river today and it bent my NSS plate and it is unable to retract. I have not taken the cover off the NSS plate to see if the actuator is bent but plan to change it anyway.
I've not done it, but on my 2015, I had a leak where the factory forgot to put adequate sealant on all of the NSS mounting holes on the port side. So I have seen it taken apart. It really is not a complex design, and you could do it yourself without too much trouble. I would bet the actuator is not bent, and try to save it just because the most difficult and important part of the job would be the wires on the actuator.
