Boat on lift now freezing temp.
  • 2skidoo
    • Aug 2013
    • 23
    • wisconsin
    • 2016 g23 2014 g23 2010 san230 2007 sv211
    Put boat in water now temp is supposed to be in mid 20's in a couple of nights.Any advice on keeping it warm enough? Small electric heater ok to use? Any idea's welcome.
  • Waterhawg
    • Jan 2017
    • 61
    • Atlanta
    • 2017 G-23
    Xtreme heater, great product
    • swc5150
      • 2240
      • Eau Claire, WI
      • MasterCraft Prostar
      Christmas tree lights surrounding the engine work well. Lower your boat to put some hull in the water too.
      '08 196LE (previous)
      '07 196LE (previous)
      2 - '06 196SE's (previous)
      • Tryathlete
        • Feb 2015
        • 217
        • Lake Villa, IL
        • 1996 Nautique Super Sport
        Make sure they are not LED.
        • tachyon
          • Mar 2012
          • 96
          • Stillwater, MN
          • 2001 Super Air Nautique
          You need wattage to keep it warm... may want a few strands of lights.
          Or a single larger bulb (like 100W).
          Also, dropping it in the water is a good idea.
          • Ablackler
            • Nov 2016
            • 7
            • Canyon Lake, TX
            • 1982 Ski Nautique 2001
            I've heard several folks use an old or inexpensive electric blanket and have had great luck with them.
            • Quinner
              • 2246
              • Correct Crafts
              Doesn't the 2016 have the blue plugs for draining, if so why not just drain it, shouldn't take more then 20 minutes.
              • OKWAKEBDR
                • 750
                • Lakefront
                • 2017 Super Air Nautique G23
                It's more like 5 minutes.
                Current: 2017 G23
                • 2skidoo
                  • Aug 2013
                  • 23
                  • wisconsin
                  I pulled the plugs but I am worried about the heater core.Any body know where it's located.
                  • Quinner
                    • 2246
                    • Correct Crafts
                    There should be a rubber hose coming from the intake manifold and the water pump, remove whichever one you can (manifold is usually easier) and blow thru it with your lungs, water should come out the adjacent drain you removed the blue plug from.
                    • OKWAKEBDR
                      • 750
                      • Lakefront
                      Yep, but I wouldn't worry about it. We had temps in the low 20s for 12+ hours here back a few months ago (which is unheard of temperatures for as far south as I am). I drained all the water just to be safe (except the heater core because I couldn't get the hose off). I stuck a drop light by the heater core. Had no problems at all. Many of my neighbors didn't anything except put a drop light in the engine compartment, and still had no problems. It really has to get really cold for a pretty extended period of time for anything bad to happen..especially if it the sun comes out and warms everything up during the day.
                      Current: 2017 G23
