2004 216TE
So I took the boat out tonight. First time out since July 2016. I filled the ballasts tanks just fine but when I went to empty them nothing happened on either side. I tried multiple times and durations. Out on the lake, I could not hear if the drain pumps were working due to the wind and other noises. So I gave up.
Once I trailered the boat back to the storage, I thought I would try again since it was quiet enough to hear if the pumps were working. I hit the port side empty first and BAM it worked immediately. Was pumping out strong. I hit the Starboard side pump and nothing, No noise from the pump at all. The Starboard fill pump purrs away and works fine. I checked the breakers and they were not tripped. Any ideas as to what's going on here?
I wonder why the port ballast drain pump wouldnt drain on the lake but did immediately when I got back to the storage?
Key pad light blinks for starboard drain pump activation but pump doesnt work.
Ballast gauges both worked properly.
Keep in mind that all pumps worked last time I used them but it has been quite a while.
Thanks!
Thanks!
