I have a 2000 air natique, i launched the boat yesterday and all it would do is click when i tried to start it. i baught a brand new batt. and new starter and it is still clicking and will not turn over. Any one have an idea of what it could be. Thanks for any help.
RE: clicking
Starter relay sounds right, but make sure all connections are good and corrosion free. If any of your battery to starter connections are just a tad bit loose it could cause a similar issue. Not enough amperage will flow causing the starter to just click instead of engaging. Check the grouds also. A loose or corroded ground can cause all kinds of weird problems.Jason
All black 2003 SANTE
-- Southern Fried --
