Plumbing Ballast
  • ButterRide
    • Apr 2016
    • 53
    • Lansing, MI
    • 1997 Super Sport
    Plumbing Ballast
    Looking for input on ballast plumbing... Is it feasible to tap into the engine water circuit for fill and drain?
    Hoping this is doable, but not sure if it might starve the engine for water, or take forever to fill, etc? Appreciate any experienced input.
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    You can tee a line into the raw water pickup before the pump assuming you are just wanting to use a single a pump. It won't starve the engine.
    • ButterRide
      • Apr 2016
      • 53
      • Lansing, MI
      • 1997 Super Sport
      Cool thanks!
      • AdamJBarn
        • Feb 2016
        • 51
        • Fishers, IN
        • 2002 Super Air Nautique 210
        Do it the right way and just hole saw through the hull.
        • Mrbigbirdmk
          • Mar 2012
          • 11
          • USA
          My best recommendation would be not to touch the engine water supply. If your gonna install ballast with pumps drill the holes for the pickups and run it the proper way.
          • a.klos
            • Dec 2007
            • 213
            • North Jersey
            • 2002 Super Sport
            I used 1-1/2 thru hull into existing hole from paddle wheel that I removed, made a manifold from 1-1/2 cross tee and ball valve, and it gave me enough water volume for 3 pumps.
            • ButterRide
              • Apr 2016
              • 53
              • Lansing, MI
              • 1997 Super Sport
              Well I think I'm just going to tsunami it this season, and do a proper install next winter with thru hull pickup.
