Disassemble reversible seat, Nautique 210.
  • ally505
    • Feb 2012
    • 178
    • Somewhere cold and wet
    • 2008 super air nautique 210, zr6.
    I'm going to reupholster the reversible seat on my 210, any tips on taking it apart? I've removed the screws on the hinge however it is still stuck fast in the middle. My guess is there are screws behind the traction pad or possibly some other fixing method?
    Thnx.
    seat pictured isn't my boat.
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    I am not sure about this at all, just a thought. Most of the vinyl cushions are pressed in with those Christmas tress fasteners. I'm wondering if that cushion is attached the same way.
    1989 Sport Nautique
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      I bet you are right...probably screws behind the "traction pad" seadek.
      • bdisney3
        • Feb 2016
        • 205
        • Phoenix
        • 2021 G23 (on order) 2018 G23 (for sale)
        There are indeed screws behind the seadek pad. When I seadek'd my boat (previously had sano there) there were six screws if I remember correctly.
        bdisney3
        18 G23
        09 SAN 210 TE (previous)
        04 Supreme V220 sp (previous)
        94 Four Winns Horizon (previous)
        • bdisney3
          • Feb 2016
          • 205
          • Phoenix
          Just realized I have a picture with the "traction pad" removed. Hope this helps. Click image for larger version
          bdisney3
          18 G23
          • ally505
            • Feb 2012
            • 178
            ****, thought that may be the case. I don't really want to tear the traction pad (or what ever it's correct name is) off just yet as seadek is not on the upgrade list just yet. Guessing it would be pretty impossible to remove the standard pad and refit it.
            • Cpan13
              • Jan 2016
              • 339
              • Canada
              • Current - 2021 G23 … Previous - 2020 Supra SL450, 2015 G23, 2014 G21, 2012 Epic 21V
              Using the above picture as a good guide you might be able to feel where the screws are and then use a circular punch to remove 6 nice circles. Use some stainless washers when you put it back together and it would be nice enough until you replace it with seadek.
