Knock sensors and tune up
  • Zulu's Ride
    • Jul 2015
    • 1
    • Harland Wisconsin
    • 2004 super Air 210
    The knock sensors on my 2004/5.7L PCM failed last year and I am getting ready to replace them. Any heads up?
    Beyond that I was planning on replacing my serpentine belt and plugs. Once I am that far any other recommendations?
    Thanks, Bill (Zulu is the dog)
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Is that a coil-over ignition or cap & rotor? If it's the latter, I'd sure replace those two parts as well.
    -Charles
    • AdamJBarn
      • Feb 2016
      • 51
      • Fishers, IN
      • 2002 Super Air Nautique 210
      Check the cap and rotor before you do plugs.
      • Quinner
        • 2246
        • Correct Crafts
        Do not use any teflon tape or similar on the threads of the knock sensor. 5.7 is likely an Excalibur, if boat is new to you or unaware when service was done last I would do a complete tune up, Cap Rotor Plugs and also the FCC filter.
        • homer12
          • Feb 2016
          • 584
          • Indianapolis, IN
          • 2004 SV211 TE
          Are you positive the knock sensors are bad? I thought mine was last year and it ended up being the wiring connection to it. I cut the old connector off and made a modified connection I found on this board.
          PS - I called my dealer to get one and he was the one that questioned it being bad. I pulled it, bench tested it and checked good.
