GS20 Piggyback Ballast?
  • Evening Shade
    • Apr 2015
    • 1295
    Has anyone added an overflow piggyback ballast system to their GS20? I attempted to do it yesterday and couldn't figure out a way to get to the rear tank overflow through hull fittings. I can see them but they are in such a tight space and oriented in such a way that I couldn't get a screw driver or nut driver on the hose clamps much less be able to pull the hoses off the fittings.
    The bow sack would be easy to plumb in, but I didn't have a fitting that I would need to do it. The rear on the other hand may be more work than I'm willing to do just because access to through hull fittings are so difficult.
    I'm open to suggestions.
