Sunstream Hydraulic lift won't lower (Boat on lift!)
  • RodneyVT
    • Jul 2015
    • 22
    • Hinesburg VT
    • 2014 Nautique 230 SA
    I have a 6500# Sunstream lift - last week put boat on lift & all was well. Now, boat is on lift & lift wont lower. Fluid is milky, which tells me water has leaked into lines. Pump is functioning, but cant seem to move lift down...... ideas?
  • azeus17
    • Feb 2008
    • 387
    • Grand Rapids, MI
    • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
    Is the pump going in the right direction?
    Worst case, start to remove the line to the cylinder and fluid should leak and the lift will fall. Be prepared to catch the fluid that sprays out of the line.
    • RodneyVT
      • Jul 2015
      • 22
      • Hinesburg VT
      Thx,
      We removed line, depressed center & got it to come down- thx for help!
      • HVL2010
        • Jan 2010
        • 138
        • Cincinnati, Oh
        • 2007 Malibu VTX
        Bad Solenoid or the valve is gummed up. Had the same problem last year. Removed the entire assembl, plugged the hole with my wife's finger ( ) and then cleaned it with a rag and some mineral spirits. Reassembled and it worked great.
        • Jakeb
          • Feb 2017
          • 54
          • Lacey, WA
          • 2015 SAN G21
          Did you talk to someone at sunstream, They have been super awesome in my area. They may help you with a tune up/parts even if its out of warranty
          • RodneyVT
            • Jul 2015
            • 22
            • Hinesburg VT
            Turns out that hose was pinched under bunk leg, got hose out & lift runs smooth again, pulling boat for the week to inspect.
            Thx for all the help
