Adding ballast bags in SV211
  • homer12
    • Feb 2016
    • 584
    • Indianapolis, IN
    • 2004 SV211 TE
    So before deciding to pull hard tanks or just run some piggy back sacs in the 211, I wanted to experiment and throw 2 400 sacks I have on top of the hard tanks. When changing to sacs or putting them in storage lockers, do I need to make any mods to keep sharp objects from puncturing sacs in there? I.e. Screws, metal brackets, etc.
  • IanDB
    • Apr 2017
    • 41
    • UK
    • Nautique 211 SV - 2005
    I've got a 211SV (2005) and I just added a 400lb sac in each rear locker and they fit perfectly. They don't interfere with the batteries either.
    They are the fly high Fat Sacs.
    Made a great difference to being able to wakesurf!
    https://youtu.be/x49MnDUlcE4
    • homer12
      • Feb 2016
      • 584
      • Indianapolis, IN
      • 2004 SV211 TE
      Ian, thanks for the tips! A couple questions about your setup -
      Did you remove the hard tanks? And you didn't worry about any screw tips anywhere?
      What was your speed here?
      Where do you set your hydrogate?
      • IanDB
        • Apr 2017
        • 41
        • UK
        Hard ballast still in the boat though. It used. The lockers have thin carpet and I didn't notice anything that would potentially cause a puncture (though the bags are tough!)
        hydro gate didn't seem to make a difference though that was in the ski position.
        Speed was 10mph dead -assuming PP is calibrated ok!
        • IanDB
          • Apr 2017
          • 41
          • UK
          Key is a wakeshaper. The Mission delta is awesome!
          • homer12
            • Feb 2016
            • 584
            • Indianapolis, IN
            • 2004 SV211 TE
ID:	520983 Great thanks for the tips! Here is my homemade wake gate device, it is a game changer and especially to be able to surf port side for these boats.
            • homer12
              • Feb 2016
              • 584
              • Indianapolis, IN
              • 2004 SV211 TE
              So, does anyone do anything about any screws from the top deck to the hull puncturing bags or is this a non-issue I'm worrying about here?
              • IanDB
                • Apr 2017
                • 41
                • UK
                My bags are in the rear quarter lockers so no issue with screws for me (just a reduction of storage space!)
                • mikenbike211
                  • Sep 2016
                  • 447
                  • New York
                  • 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
                  Here's my 08 211... 540 in each locker and in bow as well with QSWS . Hard tanks removed just me in the boat
                  • homer12
                    • Feb 2016
                    • 584
                    • Indianapolis, IN
                    • 2004 SV211 TE
                    Thanks Mike! Do you have a pic showing where your QSWS is stuck on your hull?
                    • enjoinick
                      • Mar 2017
                      • 55
                      • Land O Lakes, FL
                      • 2019 GS22 Sold - 2007 SV211 Team
                      Looking to add some more weight to the front of my boat and came along the wakemakers kits. Just checking to see if anyone has had any experience with it and if its worth the money. I have a 2007 sv211 TE to compare. Already have pigbacks 400s in the rear, interested in adding some weight up front.
                      Pigback kit
                      https://www.wakemakers.com/nautique-...m-upgrade.html
                      fly high nautique center arrow sac 650lb
                      https://www.wakemakers.com/nautique-...ocker-sac.html
                      • mikenbike211
                        • Sep 2016
                        • 447
                        • New York
                        I have mine stuck right under the ballast overflow thru hull fittings, just under surface of the water... wake is significantly better with a crew in the boat too! I am currently having an issue with my starboard bag siphoning out as we surf on the port side... I suspect the thru hull is underwater pulling weight from the bag... I might just install a one way check to solve the problem.
                        • mikenbike211
                          • Sep 2016
                          • 447
                          • New York
                          Pigback kit
                          I just looked at the link you provided on the piggyback bow arrow... not sure how the arrow will fit in the ski locker which is a rectangle unless there's an area waaaaaay ahead in the ski locker that can accommodate an arrow... just my 2 cents. How much total weight are you running in the back? You don't want to level the boat out too much or you'll lose your wake profile.
                          • enjoinick
                            • Mar 2017
                            • 55
                            • Land O Lakes, FL
                            I am having the same issue with water siphoning out on the surf side as well, simple fix i had was plugging the port after filling. Let me know how the check valve works, just worried air might need to travel from the port while filling and dumping.
                            I have 400lbs piggy-backed on top of each of the stock in the rear locker with some crew of people the boat definitely hurts to get on plane. I looked up through the ski locker and seems like arrow sack will work. Wont be a fun install tho.
                            • IanDB
                              • Apr 2017
                              • 41
                              • UK
                              Pigback kit
                              Try only half filling the extra 400's in the back and making sure the belly ballast is full.
                              I've got a sac for the front but haven't actually used it yet - https://youtu.be/x49MnDUlcE4
